Menu layering problem and menu dropdown bugs?
It will be easiest to reference a page on my published site:
https://harristype.com/font_store/bellerose_pro_family/bellerosefamily.html
I have set up a sticky nav bar, but when I scroll, items on the page scroll up in FRONT of the nav bar instead of behind it. I can’t find any settings for this.
Secondly, if you hover over the Font Store menu item, and then navigate down in the drop down menu, the last couple of items are unselectable. Before I can select one of these bottom items, the drop down menu disappears.
Try changing the Z-index in the Layout settings. Below is what I have my sticky menu set at.
Thank you! One problem down, one to go! I can honestly say Elements is feature packed, but not as user-friendly as Classic. Feels like some of the features are either buried deep, or not using terminology I understand. Hopefully the online manual will keep getting updated regularly.
Actually your remedy fixed BOTH problems. Not sure how they were related, but thank you again!
It would be interesting to check the top 5 top questions asked about Elements components and maybe have it pinned
Sticky menu and z-index needs to be 31
Centering an image
Mobile menu stuck dropped down in edit mode
Responsive over rides blue buttons
Hidden - hiding a component at different break points
30-60? second videos to show how to fix / set
