Menu not correct when opening Elements
I have a Standard menu that works fine but when I open Elements, it is not displayed correctly. It shows the collapsed menu (No menu items) unless I select the next screen size down and then reselect the initial screen size.
Not a big deal and it only seems to happen on opening Elements but thought you should now.
Video here
Thanks for the report; I think this is the visible scrollbar issue coming into play again.
This won’t affect the published/previewed site, and we’ll get this fixed in a future update :+1:
