Menu on home page not working
The menu on my homepage doesn’t seem to find the subpages within the folders. The menu which was copied from Home was used for all other pages so not sure whit works on those but not home
It looks like you need to adjust the z index for that menu. Something is before the menu and hiding it.
I tried that. Didn’t work. The menu works appropriately on mobile devices, just not desktop.
Whatever it is only affects the home page, all other pages menus work.
Ive copied one of the subpages and renamed it home, so all settings that have it working appropriately are there but as soon as it becomes the home page it gets screwed up. Even renaming it something beside home doesn’t work.
If the menu is inside another component, increase that component’s z-index.
Alternatively, decrease the component’s z-index that is hiding the menu dropdown.
The dropdown pops up so it’s not hidden, there’s just no text in the dropdown. Also, duplicated and replaced the page with a page that works, so should have all the correct settings. As soon as it becomes the landing page it messes up
Hey @colin
Would be good to share the project file, so we can have a closer look.
