Mobile display is not correct
Hello peeps, I’ve just finished my first website in Elements :partying_face: triosh3.co.uk
The site works perfectly except that on a mobile, in portrait mode, it looks weird, see image. Any suggestions as to the reason would be appreciated. Thanks, Steve.
On mobile scroll to the bottom of the page your footer section is wider than the rest of the page
Thanks Steve @upssjw, I noticed that but I don’t seem to be able to shrink it in mobile. It adapts to every other size perfectly.
Thanks for your help, Steve, much appreciated.
Solved it! As you say, the gaps needed adjusting but also setting up columns instead of rows also helped. Finally getting the hang of how Elements works but there are always so many variables it can be a bit overwhelming at times. Really appreciate your help. S
