Mobile website anomalies
site viewed on iPhone is ok…site viewed on new samsung s26u totally screwed.
picture 3 is iPhone 1 and 2 are samsung. also the so called fixed menu isn’t fixed on this one page. I remeber is something to do with the spacing but how can I change it if it shows ok on iPhone and ok when views in preview???
This happens when a component on the page is set using pixel widths and is too wide for the iPhone display.
Looks like you’re menu might be an issue, or perhaps there is something further down the page…
the iPhone is perfect the samsung isn’t ? also menu disappears on samsung but is ok on everything else
1 picture is the editor 1 is what shows on iPhone look at April 6th
e
It’ll be something to do with an item on your page that the Samsung browser doesn’t like, perhaps the text is displaying bigger on Android due to font rendering, and that causing issues… it’s hard to know without testing the page on an android device…
An easy way for you to track down the problem is to delete components on the page one-by-one, until the issue disappears. Once you know what content is causing the issue you can work on tweaking it so it works on Android.
You can preview these changes live, by using the network web server feature available in the advanced section:
thanks that cured it…changed text size on mobile phone…its always something simple…thanks for the idea
