I am experiencing a fliggering when using the opacity slider in the modal component. I think I also have seen that in your video @dan. So I am sure you guys know about that, but we have it documented now
I would say the problem is the tailwind class, as you can see in the video.
While in the documentation for the colors they reference this: <div class="bg-pink-500/[71.37%]"><!-- ... --></div>
For custom opacity that is not set together with a color they state this: <button class="opacity-[.67] ...">
Seems to me a inconsitency. But yeah is easier to complain then solving.
Nevertheless when looking at the code that it genereted in Elements we have that: <div class="fixed inset-0 bg-black/25 bg-surface-950/[34%] [34%] backdrop-blur-[5px] pointer-events-none" x-transition.opacity="" x-dialog:overlay=""></div>
Where I would see an issue with the standalone [34%] behind the color. But yeah just an observation.
I’ve also seen this, we need to take a closer look as to why this is happening!
In this instance you can use a percentage value for the background colour opacity. Both syntaxes are actually valid here.
I do think we might want to be more consistent and use the decimal notation everywhere, and ensure the values are rounded to the closest whole number, so we’d be doing bg-pink-500/[0.71] in the above example.
That shouldn’t be in the exported HTML, but it won’t cause an issue as there won’t be any CSS generate for an “unknown” or “invalid” tailwind class.
This won’t work bg-pink-500/[0.71] only bg-pink-500/[71%] is valid. That’s why I meant inconsistent. Tested that in the browser. The first one just removed the color.
This actually has nothing to do with the CSS, it’s an issue with an @portal call.
Also, I know this is pedantic, but just for anyone reading: both bg-pink-500/[0.71] and bg-pink-500/[71%] are in fact valid tailwind classes. You can do either, as demonstrated here: Tailwind Play
Actually, you should be building for tailwind 4.1 now - and to be uniform, it should be in format bg-pink-500/71 You get richer colors as a bonus. And fyi - *-opacity-* has been removed.
