More responsive properties
I have a Hero with a photo background. On mobile I need a semi-transparent white panel behind the text for readability. On tablet and desktop I want the panel to disappear because the image provides enough contrast. At the moment this is impossible without duplicating the layout or using custom CSS.
I think more properties should be made responsive, this should have a high priority.
Regards
If I’m not mistaken, you can probably do the same things with the current tools. By placing an empty container in Absolute with a color, between the photo and text, you can decide when to hide it in other layouts.
Updated - Apologies assume you already have tried these by your comments
two ways here, lots of other ways, - elementsapp://downloadDocument/vzV83DUezlZY
not sure why text does not have a background color
it would be simpler if the the color control had a blue dot
@dan when Realmac where asking for suggestions (must have been 20 months ago?) I requested this be implemented it was on the list, no idea what happened to it
Michelangelo, Steve
Thanks for the alternatives suggested to me!
Regards
