I recently added a link to this Spunky’s Kitchen text. Doing so caused the text to turn black. I changed it back to its original color (shown here). Since adding the link, loading and navigating my project in Elements has screeched to a crawl, and the text color will change to black and nothing I do gets it back to the correct color except closing and reopening the project. Does anyone have a suggestions for a fix?
On your link in the inspector you have two colour choices one for static and one for hover. Go to your link and change the colours as required. As to the speed perhaps @dan could help but a s always put project in cloud and put a link here or if you want to keep it private send it to support and they’ll help
I changed the color settings on the text @PMUK, so far so good.
To troubleshoot the SLOWness of my project. I duplicated my project. Then I started to delete components. The more components I deleted, the faster my project responded. I don’t recall this effect being as significant in the past. @dan I can send you my project if you want to test. You can see my site here: https://www.kieffer.us
