Nagivation panel
How can I create more space between the logo and the text in the navigation bar?
What is the purpose of the text “color” and “general” in the panel for the logo in the navigation component?
I also had a navigation question:
  • How do you add images to the far right dropzone area (assume svg support will happen eventually)?
Also, put an info line in there for Logo, so we know the image is coming from project settings.
Looking at the problem w/ space between the logo - the logo has flex-1 assigned but I would suggest a flex:none on it to allow the space around to work properly.
You simply put an SVG or IMAGE component in the dropzone.
Nope, can’t drop image from resources into right dropzone and now I’m wondering what the Dropzone tab is for, as I can’t drop image into that left dropzone either - I’m on beta 19.
Please read my answer again. I wasn’t talking about an image, but the image (or svg) COMPONENT.
Like you can put a button component or a text component in there…
Lol - I just wouldn’t of thought to do that - I just think too literal about things - thanks for the help :slight_smile:
