Hey everyone,
I’m curious to know if anyone has gotten a nav bar to do something like the mockup in the image I’m posting. I built what you see with just straight components but would like to do it with the Nav component.
The Navigation component doesn’t support this, style of split navigation. Seems like a tricky problem to solve automatically ![]()
What do you think @ben, got any ideas on this?
it’s actually pretty difficult to add support for center aligned logos in the Menu component, mainly due to all of the different options and styling conflicting with each other.
Your best bet is to do as you’ve done, build the layout using the Core components
If you need any help, just let me know!
