Need help with Form setup
No e-mail gets sent. The log I downloaded from the server (php 8.4.2) shows very confusing lines. Different results are logical consequences of fiddling with the settings in the inspector. But what I find particularly weird is that the log is telling me there should be a webhook, while I never activated a webhook.
Are my settings correct?
Can anyone help?
I think the from address and the to address should be the same…they are on my forms…also try the TLS security 587
Yes, @Godber is correct, the from address and the to address should be the same.
We also have a troubleshooting guide to help users with form setup, you should run through that as it often helps resolve most issues.
Hope that helps!
Solved. The problem was not in Rapidweaver Elements. It was a serverside problem with split MX that I managed to solve. Actually, it now works, even with different to address. (same domainname though). If anyone likes to know more, I’ld be happy to share a FAILING six hour conversation with ChatGPT for a problem Claude Opus solved in minutes. Just let me know.
Thanks guys.
Woah, what a pain, glad you got it sorted though :tada:
