Need Replacement for RW Lockdown Plugin
Need a Replacement for RWC Lockdown Plugin. (I am running RW7.). I discovered that when I moved to Mac OS 13.6, the Mac OS says it cannot verify the Lockdown Plug-in Developer, therefore will not open my project since it uses the Lockdown Plug-in to protect several sections of my web project. RW7 Support says that the Lockdown Plug-in is no longer supported or updated, so I need another option to protect those sections. Any suggestions would be appreciated.
Hi @AlF,
If you’re using the Stacks plugin already, you could take a look at UserAccess Management ($50, inStacks Software).
If you’re looking or a replacement that’s compatible with all types of RapidWeaver projects (both Stacks and standard RapidWeaver), take a look at Sitelok ($60, vibralogix.com).
Erwin
