New project crash
Hello!
When I start RapidWeaver, a dialog box does not appear, and when I start a new project, the program crashes.
Can you please tell me why this is happening?
I tried different versions of RapidWeaver 8.
Thanks in advance.
Support Logs:
2020-06-17 16:19:53.486 RapidWeaver 8[4439:148261] ==============================================================
2020-06-17 16:19:53.486 RapidWeaver 8[4439:148261] RW 8.6.1 (20831) LAUNCHED (2020-06-17 14:19:53 +0000) macOS 10.15.5
2020-06-17 16:19:53.488 RapidWeaver 8[4439:148261] [Crashlytics] Version 3.13.1 (140)
2020-06-17 16:19:53.494 RapidWeaver 8[4439:148261] Application Will Finish Launching
2020-06-17 16:19:53.495 RapidWeaver 8[4439:148261] checkAccessToAddons
2020-06-17 16:19:53.495 RapidWeaver 8[4439:148261] Install and load addons
2020-06-17 16:19:53.496 RapidWeaver 8[4439:148261] Loading bundled themes
2020-06-17 16:19:53.538 RapidWeaver 8[4439:148261] Loading bundled plugins
2020-06-17 16:19:53.546 RapidWeaver 8[4439:148261] Loading 3rd party plugins
2020-06-17 16:19:53.547 RapidWeaver 8[4439:148261] Loading 3rd party themes
2020-06-17 16:19:53.547 RapidWeaver 8[4439:148261] Categorising themes
2020-06-17 16:19:53.557 RapidWeaver 8[4439:148293] [Crashlytics:Crash:Reports] Packaged report with id ‘9fad657988d04804a7d4702629dd8adc’ for submission
2020-06-17 16:19:53.639 RapidWeaver 8[4439:148261] Initializing plugins
2020-06-17 16:19:53.639 RapidWeaver 8[4439:148261] Loading plugin: /Applications/RapidWeaver 8.app/Contents/PlugIns/Blog.rapidweaverplugin
2020-06-17 16:19:53.647 RapidWeaver 8[4439:148261] Loading plugin: /Applications/RapidWeaver 8.app/Contents/PlugIns/Contact Form.rapidweaverplugin
2020-06-17 16:19:53.652 RapidWeaver 8[4439:148261] Loading plugin: /Applications/RapidWeaver 8.app/Contents/PlugIns/FileSharing.rapidweaverplugin
2020-06-17 16:19:53.656 RapidWeaver 8[4439:148261] Loading plugin: /Applications/RapidWeaver 8.app/Contents/PlugIns/HTML.rapidweaverplugin
2020-06-17 16:19:53.660 RapidWeaver 8[4439:148261] Loading plugin: /Applications/RapidWeaver 8.app/Contents/PlugIns/iFrame.rapidweaverplugin
2020-06-17 16:19:53.664 RapidWeaver 8[4439:148261] Loading plugin: /Applications/RapidWeaver 8.app/Contents/PlugIns/Markdown.rapidweaverplugin
2020-06-17 16:19:53.669 RapidWeaver 8[4439:148261] Loading plugin: /Applications/RapidWeaver 8.app/Contents/PlugIns/Movie Album.rapidweaverplugin
2020-06-17 16:19:53.682 RapidWeaver 8[4439:148261] Loading plugin: /Applications/RapidWeaver 8.app/Contents/PlugIns/OffsitePage.rapidweaverplugin
2020-06-17 16:19:53.686 RapidWeaver 8[4439:148261] Loading plugin: /Applications/RapidWeaver 8.app/Contents/PlugIns/PhotoAlbum.rapidweaverplugin
2020-06-17 16:19:53.691 RapidWeaver 8[4439:148261] Loading plugin: /Applications/RapidWeaver 8.app/Contents/PlugIns/Quicktime.rapidweaverplugin
2020-06-17 16:19:53.695 RapidWeaver 8[4439:148261] Loading plugin: /Applications/RapidWeaver 8.app/Contents/PlugIns/Sitemap.rapidweaverplugin
2020-06-17 16:19:53.699 RapidWeaver 8[4439:148261] Loading plugin: /Applications/RapidWeaver 8.app/Contents/PlugIns/Styled.rapidweaverplugin
2020-06-17 16:19:53.704 RapidWeaver 8[4439:148261] Plugin Author Version
2020-06-17 16:19:53.704 RapidWeaver 8[4439:148261] ------------------------------------------------------------
2020-06-17 16:19:53.704 RapidWeaver 8[4439:148261] Blog Realmac Software 7.0
2020-06-17 16:19:53.704 RapidWeaver 8[4439:148261] Contact Form Realmac Software 7.0
2020-06-17 16:19:53.704 RapidWeaver 8[4439:148261] File Sharing Realmac Software 7.0
2020-06-17 16:19:53.704 RapidWeaver 8[4439:148261] HTML Code Realmac Software 7.0
2020-06-17 16:19:53.704 RapidWeaver 8[4439:148261] iFrame Realmac Software 7.0
2020-06-17 16:19:53.704 RapidWeaver 8[4439:148261] Markdown Realmac Software 7.0
2020-06-17 16:19:53.704 RapidWeaver 8[4439:148261] Movie Album Realmac Software 7.0
2020-06-17 16:19:53.705 RapidWeaver 8[4439:148261] Offsite Page Realmac Software 7.0
2020-06-17 16:19:53.705 RapidWeaver 8[4439:148261] Photo Album Realmac Software 7.0
2020-06-17 16:19:53.705 RapidWeaver 8[4439:148261] PluginName Realmac Software 7.0
2020-06-17 16:19:53.705 RapidWeaver 8[4439:148261] Sitemap Realmac Software 7.0
2020-06-17 16:19:53.705 RapidWeaver 8[4439:148261] Styled Text Realmac Software 7.0
2020-06-17 16:19:53.877 RapidWeaver 8[4439:148261] Application Did Finish Launching
2020-06-17 16:19:53.880 RapidWeaver 8[4439:148261] Application Should Continue Launching
2020-06-17 16:19:53.881 RapidWeaver 8[4439:148261] data parameter is nil
2020-06-17 16:19:57.245 RapidWeaver 8[4439:148261] *** Assertion failure in -[MGSSyntaxController loadSyntaxDefinitions], /GitHub/RapidWeaver8/RapidWeaver/RWKit/Vendor/Fragaria/MGSSyntaxController.m:291
Perhaps a question for @tpbradley?
What dialog box are you looking for?
Are you running RapidWeaver from the applications folder?
Sorry, “Projects Window”
16
59
Yes
Hey @Fame, from the log you provided it looks like the app may be damaged. Could you try downloading a new copy using this link and give it another go?
https://github.com/realmacsoftware/RapidWeaver8-releases/releases/download/8.6.2-(20836)/RapidWeaver8.zip
Cheers
@tpbradley, thank you!
It was an issue with the archiver.
Before I expanded archives of RapidWeaver using the plug-in built into the file manager (Double Commander). There haven’t been any troubles with it before.
After your message about the archive damage I expanded using a different program.
Now everything is working!
Thanks once again!
That’s excellent news, happy weaving!
