No panel for controlling Flex box properties
Somehow my version of elements has lost the control window for adjusting Flex box properties
Right click on I⃝
. Go to “Panels”, and add “Inspector”.
The property is visible at the top of your left panel.
And what happens if you click on inspector?
I don’t see ‘I’ to follow your first step.
If you click on the icon (see arrow), you should have the control window. If not, contact @dan or @ben
You can also reset your workspace using the workspace manager in the toolbar :slight_smile:
that icon is missing in my menu bar
(attachments)
Hi @traut,
Take a look at the video in the user guide, it’ll explain how the workspaces feature works. As @iMac points out, you’ve moved your component inspector into the area on the left of the window.
OK, have done that, but the information menu does not see my Flex image
(attachments)
I hope this helps …
Whoopee! that worked.
