Not all folders and files are published
A large part of my pages are not being published to the server. I simply published and also used Re-Publish All Files. I have the impression that certain folders are not being published, without any clear reason. In the folder /uitwedstrijden/, the folder /jupilerproleague
is created correctly and the subpages are published properly, but the subfolders /crokycup and /europees are nowhere to be found.
Thanks @Bartje, I’m looking into this today and will hopefully have a fix soon!
@Bartje I’m having some trouble reproducing this one, are you able to upload a copy of the project to Elements Cloud so I can take a look?
Cheers
Hi Tom,
Hope this helps: Project
Hi @Bartje,
That project was very helpful indeed! At first I thought it might have been a publishing issue, but then I spotted that these pages have been set to draft. If you click on the cloud to turn off the draft status, do they publish ok?
Cheers
That was the trick ! Thanks Tom. No idea why those pages were set to draft :man_facepalming:
Excellent, that’s great news!
