Note to Self:
Note to Self:
  1. Remember to save often. System might crash.
  2. Remember to click on the little dot before changing parameters for breakpoints.
  3. Remember to hide pages that aren’t finished yet.
  4. Don’t save your project in OneDrive folder… When synching, it can’t locate where to save.
  5. When making lots of changes, do a {save as} because you will certainly want to go back and redo from where you started this time.
What’s the matter with point 2? Why should I click on the dot?
Don’t forget you can also backup your project to Elements Cloud every so often. It’s handy to have an offsite backup :blush:
If you don’t, you also change the settings for mobile.
Thanks for this info, didn’t know that!
Could you have a version of Elements without the Cloud service? Really dont need it and if it means the subscription is cheaper, then maybe I will get the PLUS subscription.
Elements Cloud is our free service that allows all users to backup and share their projects — there’s no extra cost and it’s included in all plans :slight_smile:
