One Gremlin goes, another arrives
Being only a “casual” dabbler in websites (re-juvenating a site for local gem club), I am trying to grapple the CMS part of elements..
What was working yesterday, the latest update (1.3) stuffed it up again. Being no code wizard, I am stumped !
=========================== error dump========================
Warning: require_once(/Applications/ServBay/www/test/post/../../rw/elements/com.realmac.corepack/api/vendor/autoload.php): Failed to open stream: No such file or directory in /Applications/ServBay/www/test/post/index.php on line 4
Fatal error: Uncaught Error: Failed opening required ‘/Applications/ServBay/www/test/post/../../rw/elements/com.realmac.corepack/api/vendor/autoload.php’ (include_path=‘.:/Applications/ServBay/package/php/8.3/8.3.23/lib/php’) in /Applications/ServBay/www/test/post/index.php:4 Stack trace: #0 {main} thrown in /Applications/ServBay/www/test/post/index.php on line 4
If you need the whole ‘project ‘ (8mb) let me know how and where please..
Apart from that I am enjoying the ride from RapidWeaver Classic to Elements - great work !
(elementsapp://downloadDocument/plL2cM2btAG9)
Hi @Utz
This error suggests that some of the files are not available when previewing — this could be a local cache issue.
Have you tried restarting Elements and/or your Mac as I think that will likely fix this issue. Give that a try and let us know how you get on :slight_smile:
Hi Ben, did as suggested and problem persists. I tried different versions of php (8.4.10) on the local server, but that didn’t change anything either. The problem appears in local preview as well as in publishing to local servers (ServBay and/or MAMP).
Is there any way to install the previous version of elements in order to test a ‘version problem’ ?
P.S. the project is attached in previous message (and here).. (elementsapp://downloadDocument/plL2cM2btAG9)
Thanks for the project, that’s most helpful.
Elements 1.3.1 is being released later today and will fix this issue for you, sorry for the inconvenience!
