Page Inspector Visibility
I just started a new project.
When I go to “Page Inspector” all of the options are so light that I can’t read it.
How do I change the color of the options so they can be read in “Page Inspector”?
Thanks,
Alan
What version of RW are you using? It sounds like you may be running in dark mode with a version of RW that doesn’t support it.
I am using 7.5.7
Do I have to upgrade to version 8 to correct this?
Thanks Scott!
If you want to run in dark mode, you need RW8 I believe. You can switch to lightmode and RW7 should work Okay,
Thanks - Just upgraded to 8 and we are all good.
