Page rendering
I’m having difficulty with a couple of the pages I have created for a project not rendering the same way when i upload them to my webspace and when i do preview also.
I’ve tried to upload screenshots of what happens but it’s not letting me post “media”.
I’ve uploaded the site to my cloud space, called junior academy website 2
It happens on the home page and also on the pages where I have buttons with a book now link inside the button.
The live link to the site is www.b3golf.co.uk
Is anyone able to help? thx
Sorry to hear you’re having issues, but don’t worry, we’ll get to the bottom of this and get your site publishing perfectly!
Can you try using the “Re-publish All files” command and see if that fixes the issue for you.
If the issues persists, can you let me know if you are you using any custom code or components in your project?
Hi, when I select re-publish all files it says the publishing destination is not configured properly. I’ve been exporting the files to a local folder on my computer and then i copy and paste those files into FileZilla. I have re-published using this method multiple times.
It appears in the same manner as it does on the live website when I click on the preview button in the top right in elements.
I don’t think I’m using any custom elements, other than what comes in the essentials pack.
If you’re seeing this error, make sure you have entered your website URL (and your FTP details) in both of these fields:
Once you’ve done this, try using the Re-publish all files command again.
i’ve done that but it still comes up with the same error when i press to re-publish the files. Ive applied for ssl certificate and host says they will install it when its issued from certification authority.
Hi @PhilBonfanti
Can you upload your project file to Elements Cloud and send it over? Feel free to DM it if you don’t want to share it here on the forum.
Seems like something with the button inside of those containers is causing it but I haven’t pinned it down yet. If I remove the button they everythings displays fine.
Ah, the cards might be linked with another link inside of it. You can’t nest href links… (this issue only presents it’s self in Preview/Publish)
Ah, that’s it. Thanks. :blush:
thx that’s worked, easy when you know
