Panels: font sizes
RapidWeaver Elements 0.9.6 (23600)
Hi - new Elements user here.
I realise it’s still under development, but the UI could be improved to make readability much easier on the eyes. The left-hand panel showing the Pages, Resources, and Components is far too dim and icons very small. I’d like to see a config setting to allow font and icon sizes to be changed for readability.
Hmmm, the contrast seems quite good here :thinking:
Can you post a screenshot of how it looks on your Mac?
have you tried the list view instead?
List view - Indeed - the fonts are marginally bigger, but the icons remain the same size. It’s not just this particular panel that’s affected - the right hand panel showing the component settings is similar.
It’s just a pain to try and read. Ideally a good solution would be to have a config setting that allows a user to make the text bigger, or even bold.
If it’s too difficult, then perhaps changing the panel background (as a config item) so as to highlight the text may be another good solution?
or specsavers!!! hahaha
Experiencing the same here right now .. any progress?
