Was able to build a parallax component. And the preview in Elements is amazing. All is working really good so far.
Phew, glad you got it working!
Would like to see the parallax component in action (as it is something we probably need to build into Elements) — do you have a video I can take a look at?
I can not upload videos here ![]()
Other then that the simple one is done ![]()
Annoyingly the forum doesn’t support video. You can always upload to YouTube and set it to unlisted.
I use CleanShot X, it’s super good and has video hosting built-in ![]()
Hi @Dan,
yeah I saw the Cleanshot stuff. And was just in the middle of purchasing a license when my internet crashed. Looks like its a super app for the one (and only one) app I miss from Windows. (Greenshot)
That is looking great - nice work ![]()
had a go at parallax
quick demo, this will have issues but if you could test
Hi @upssjw,
the one I build works differently. Its like a parallax per added container and then have that container accapting content.
You are working with a background Image that you overlay stuff. So would be limited to one picture.
Yes just wrote it quickly as I had not tried parallax before, need to investigate the multi image I’ll take look tomorrow if I have time or move on to something else which I normally tend to do
Nice looks cool
If you are on a Mac, use
Shift-Cmd-3 to take a screen shot
Shift-Cmd-4 to select a portion of the screen to snapshot.
Shift-Cmd-5 to do screen recording.
Hi @RussOggi255
Yeah I know that. But I was always unhappy with those default functions. So Cleanshot X is actually the solution I was missing the last 3 years already.
- Pixelate Functionality
- Easier Annocation
- Better Screen Recording
Just never seen it before. I used Greenshot in my previous job and was looking for something like that ever since.
CleanShot X is excellent, couldn’t live without it now!
added a line of code and multi backgrounds, couldn’t resist
AWESOMMMMMEEEE … ![]()
Would be nice to see how you solved it. If you like to share. I used a dev pack.
ill add the ui for the rest I added and then share as a project
project here not finished or tested, have some dev packs but like to get them almost complete, only about 6 or 7 lines of tailwind
into para content you can change for div I was testing in Whisk, updated file
elementsapp://downloadDocument/vWn5LgQ58B4D
see video, feel free to test critique or if I should add
