Password Protect - Best practice to protect entire project
Hi guys. I have purchased “Password protect” and would like to protect the entire page. Is it enough to drop the “Password Page” component once on top of the front page and all subpages will be automatically protected? Or do I need to install the component on all pages? On a test page it looks like that the main domain is protected but subpages not. Thanks for your advices!
Short update. It looks like each page needs the Password protect component. Copied and pasted the component into each subpage and the logout button once into the main page. This way I can log out once and all pages seem to protected now.
Glad you got it sorted. You can also set the Password component as a Global, that way if you ever need to update the ID or other settings you can just do it in one place :slight_smile:
