Pasted text not wrapping lines
I am a newbie to Elements, I have created a page using a container, which has a 2 column grid in it, each column in the grid is a text box to produce two columns.
I have taken a block of text from existing Classic page and pasted it into the one column, I understand it looses the bold etc but it is not wrapping the text and instead loosing the righ hand side.
Is there something I am missing to get this text wrapped.
If I understood you correctly, is this what you wanted??
Yes I am after two columns down the page with text boxes in them
If you want it justified, make sure you click the justified button in Text box settings
the aim is to also put dividers between each block vertically and also random images in teh columns as well
I have tried that but for the left column when you click on the text block it is showing the right hand side as being over on the right hand side of the page and not in the middle where the grid column should end
Borders…
Do you have a picture?? I don’t quite get what you’re describing.
You can also try changing the spacing (margins or padding) to see if that helps.
It says I cant embed a media image
I think you have to post a few more times and then it will let you…
Per chance, did you set your grid to be 2 columns??
ok I will try again with your suggestions on margins etc.
Basically I have
Grid
Container
text
text
text
Container
text
the first three text boxes span the full width, the last text box is only one of correct width.
Yes I did set it to 2 Columns
Without seeing the actual Node Browser, make sure that the container is IN the grid, and make sure the text components are IN the respective containers.
they are , the above didnt indent with spaces the two containers are indented under grid and the text boxes indented under each container
I will scrap it and retry from scratch, thanks
Like This??:
Thats what I am trying to get but the left column text is spanning behind the righ column for some reason
Try adding a bit of padding left and right and see if that fixes it. (or at least cleans it up some
Will try, thanks
