Pasting Multiple Components
@dan There is an issue with pasting a group of selected components where the paste does not place the components in the order they were when copied. The paste seems to result in them being randomized. This can be very frustrating as you then have to reorder them after the paste.
Are there any plans to fix this issue?
Related to cut, copy, and paste. Are there any plans to support copying and pasting from the Pages Pane?
Hey @handshaper,
I’ve added a ticket to get this solved, thanks!
Yep, should be able to do this too. I’ve added a ticket!
@handshaper Good news!
This has been fixed in build 0.8.5, available now :tada:
Fantastic! You guys are the best.
