I am interested in Elements for my small business, but I would like to know if my customers can pay invoices that are mailed to them online. If anyone knows the answer please let me know.
thanks
I can’t see that being a feature of Elements rather than a behaviour of your website, unless I am missing something?
Invoices are mailed to patients / customers. On the invoice I would like to have something like “pay online at www.mybusinesswebsite.com” then they can navigate there put in their info name, invoice number, payment.
Sounds like you need a separate payment solution from a 3rd party that you then embed into your website using some custom html / component. That’s nothing elements handles out of the box.
I have no experience with paying solutions, but as far as I know do most of them offer some sort of html snippet which you can embed. Not sure if there’s something tailored to your special needs. But you never know ![]()
You’ll need to find an online invoicing system and integrate it into your Elements website (it won’t be tricky, probably just a line of code). You could use something like Stripe or Square.
I send invoices out with Cartloom, which is fully integrated with ELEMENTS, I use card payments and Stripe through Cartloom and have been using this method for years without any problem.
I use this approach as well and it works great. It was very easy to integrate Cartloom into Elements with a custom product component. I also use it for my website stores and it works well.
