PHP Fixes: Antenna - Previous/Next - CMS Audio - PDF Viewer
Antenna
CMS Audio Player with Links
CMS Prev Next
PDF Viewer
Very cool, I like that they are on GitHub!
You might want to update all the Read Me files with a link back to www.realmacsoftware.com/elements so anyone coming across them, can easily find out more :blush:
This also helps us SEO wise :wink:
Good idea will do… Claude is a great assistant :slight_smile: added to the first sentence of each…
PHP - stability improvements and bug fixes - download new versions!
