Just purchased the Elements Portfolio project from the store. It indicates it was purchased and installed. Any thoughts as to where it was installed as I’m not able to find it. Thank you, Charlie
When you click on new project, it should be one of the choices you can select.
I found the project as well as the before & after project that I also purchased. They are accessed via “New Project” option
Hi @cjk
Thanks for supporting us
happy you’ve already found where you can open the project, do let us know if you have any other questions!
