Positioning inside a Flex
I am trying to customise the layout in one of the Menu items in the Essentials pack.
I want my logo (SVG) on the left and the menu on the right of the page. I was trying to do this manually as it came but it only had one button the menu.
So I tried to change this by putting the menu button and a SVG element into a Flex to try and make it easier. Then changing to Row in the Flexbox settings. That got me so far.
How do I get them to opposite sites of the page?
There are three menus in core pack Standard/Sticky/Fixed if you copy one of these into project you will see all have menu on left and hamburger on right sides. Is this what you are trying to achieve. If so Strat with one of these to check your settings and layout in the node tree.
I hope this helps you?
“Between”
Got there in the end. Didn’t get it from the build in menus just had a better play with the Flex
