Possible Aspect Ratio Bug
I’m trying to give a custom 1/1 aspect on mobile image, then move to Tall on SM and MD, then move back to 1/1 on LG and above. Elements doesn’t seem to like it, the custom ration becomes none responsive to the custom ratio at certain breakpoints. At mobile is goes to “wide” even though I have 1/1 in set in custom. SM and MD shows correctly as it’s set to Tall. LG and above is stuck at Tall even though I have it set to 1/1.
dont think you can mix aspect ratio and custom ratio, for the tall screens set custom aspect to say 4/6 or what ever you need, then they should work, could be wrong, not at laptop
As I often say, it’s really hard to know what’s going on without seeing the project…
Can you share an example project we can take a look?
Hi Dan,
Here’s the project I’m working on. It’s the section about half way down that has an h2 that says “Service Options Designed Around Your Business Reality”
elementsapp://downloadDocument/6C8jroFg8mYZ
keep them all custom ratio, (cant mix aspect and custom) )for the small & md set to say 5/7. just blue dot them
this is the solution! :slight_smile:
@ajenks keep everything custom and override that across devices. If you need any more help with this, just let us know :slight_smile:
