Pretty URL - when more than one per website
I’m trying to set up pretty URLs for my website, but I can only get it to work partly. I suspect the problem is that I have set up three separate CMS sections on my website, one for a traditional blog, one for image galleries and one for my policies.
Can I have more than one pretty URL per website when using Elements CMS?
If so, how do I resolve the <base href="/"> issue of having more than one cause conflicts?
I can follow the instructions on the CMS docs page and create three .htaccess files for each subfolder.
You can use multiple Pretty URLs within a single website when using Elements CMS.
Of course, you need to adjust the rules in your .htaccess file for each CMS section you have set up.
The important thing is that you do not create three separate .htaccess files. Instead, you should include all the necessary rules for your different CMS sections in a single .htaccess file.
In general, using Pretty URLs for multiple different directories is no problem at all. I currently have more than 50 different CMS sections set up this way, and I can add additional ones at any time without any issues.
As for exactly what your .htaccess rules should look like, that’s difficult to say without seeing some specific examples of your URLs and folder structure.
Thanks @Pegasus
The trick - as you say- is just to have one main .htaccess file. I was adhering too strictly to the instructions of the CMS docs page and trying the subfolder.
