Preview vs Publish
How can I have a perfect preview and when I publish everything is broken? I am so frustrated. I don’t even know how to share what is good vs what is garbage?
It sounds to me like something has gone wrong with the publishing.
If you Mark All Pages & Resources as Changed and then Re-Publish All Files does that work? If it was me I would export the site to my HD and then use an FTP client to compare the file structure with that on the host server. Something must be missing if it looks good on Preview.
Assuming you are not using the trial version which has publishing limitations?
I have done all of that a million times and no I am fully vested
Try deleting all files from server, then republish all files and see if that changes anything.
