Several times, after publishing, the “export” window appears after the notification says it’s published. Something also went wrong with the autosave. And RW is blocked… had to force quitting.
Couldn’t publish after, had to duplicate the file.
RW Version 7.0.2
I’ve also had that problem a few times. I saved as a new document and eventually the problem resolved. Not a solution, but a livable workaround.
It’s was the same with version 6… Just to inform.
