Problem with bulleted lists
Hi all,
A while back, I created several pages with bulleted lists. I used instructions I received here in the forums about how to do this. One of the pages is working perfectly:
The other pages, not so much:
I constructed all the lists using the same method, so I’m scratching my head wondering what I did wrong. Here is a screenshot of the above page in Elements:
When you compare it to the page in the first screenshot, you can see that it doesn’t look the same, even though I followed the same instructions (or so I thought) to construct both:
Can anyone help me correct this?
Thanks!
what is your flex set to row in one and column in the other?
They are both set to column.
I manually redid all the bulleted lists and now they work.
