Help, I can no longer export. Not even to a local folder.
Everything still worked this morning. Then I uploaded a few changes to the web server. Since some things didn’t work, I deleted the content of the folder on the web server with an FTP client and then tried to upload everything again with Elements. Unfortunately, this did not work. My attempt to export everything to a local folder didn’t work either. This window always appears
I worked around the problem by restoring an old copy with Timemaschine and then implementing my changes.
The file that I can edit with Elements but cannot publish cannot be uploaded to the cloud either. See screenshot.
after the error just occurred and the upload to the cloud did not work, the error has now unexplainably disappeared. The upload to the cloud also works now. This is somewhat unsatisfactory, because the error was really there.
Sounds like your older project may have gotten corrupted somehow. If you’re still having issues you can email the project over to me - dan at realmac software dot com.
