When I use the letters æ, ø, and å in Forms, they don’t display correctly in the received email. Bjørn appears as Bjørn.
How can I send a copy to the sender of the Form?
We’ll look in to this one, and try and get a fix in the next beta.
We don’t support sending a copy of the email to the sender of the form.
You would have to use the Webhooks feature, and process the form data on a service such as Zapier.
Hello @ben There are still issues with Norwegian characters in Forms. There is now a new problem. Checkbox only remembers the last checked box. See images.
Just checked this one, and it’s definitely working in the latest build. Could I get you to try and “Re-Publish all files” to ensure the updated PHP API is up to date.
This one is a bug in the current beta.
I’ve found and fixed the issue - this will be updated in the next build ![]()
After Re-Publish å, ø and å works fine ![]()
