This gym website project is designed for fitness centers, personal trainers, and wellness studios looking for a bold and modern online presence. Built for RapidWeaver Elements, it features a sleek layout, dynamic sections for classes, memberships, and trainers, and a responsive design that looks great on any device!
thanks for providing the template “fitness”.
I took a close look at the project file and noticed a BUG under mobile. responsive on my mac it all looks very good and works without any problems.
unfortunately the website is not displayed correctly on my iphone under safari & arc browser.
Do you or anyone else have the same problem on the iPhone?
This is often caused by an element having a set width (wider than mobile). If you scroll down the page, does anything stick out on the right-hand side?
I will take a look and get this fixed up, I’m just doing an update to the project to add a form ![]()
yes, i can see the scrolling effect on my mobile device.
many thanks for updating the project ![]()
If you scroll down the page, does anything stick out on the right-hand side? that will be what’s causing the issue…
I’ve not updated it yet…
here is a link to a short screenvideo.
Thanks, that’s very helpful! I’ll get it fixed up shortly.
@Pegasus Just a quick update on this… it was the Reveal animations causing the issue (they are coming in from the sides).
I’ve now fixed the issue and added another page design and a contact form!
The new update will go live when we ship the Form Components (very soon).
