My project isn’t listed in the recent projects list on start-up of Elements.
It uses the macOS system recent files features, so might just be the Finder playing up. Try restarting your Mac and see if that fixes things.
Tried that and still no projects showing up in recents list. Also checked Finder settings and is set to show recents, and recents show in apple menu → Recent Items.
Have you tried the oldest trick in the book? Restarting your Mac…
Let me know how you get on!
Yes. Tried restarting and no change…I can try again
Turned it off and on again…
No, nothing in menu or in start-up screen
This really feels like an issue with macOS… but what exactly I don’t know ![]()
Solved. While settings were set correctly, I had set recents to 0 in Onyx some time ago. Reset it there and seeing project in the recents list now.
Phew, glad you got it sorted!
