Just bought RW6 and the start screen has NO CONTROLS.
It registered fine. Did I do something wrong? Is it a bug?
Please help.
What happens if you right- or CTRL-click the tool bar (at the top) and single-click on ‘Customize Toolbar…’?
Can you add the missing icons?
Yep. That did it. You rock. Sorry for total beginners question.
mujo,
So glad it helped; beginners always welcome - and their (probably useful to others) questions!
Good luck
