Hi there! I published couple of new pages of my site, this happened regularly.
Afterwards my site is viewable on line, but my project is viewable enterely just in mode ‘preview’ and just very partially in mode ‘edit’, which is clearly regrettable.
Can I do something to restore the mode ‘edit’ as the mode ‘preview’.
Thanks. Paolo
Not sure what you mean here with " just very partially in mode ‘edit’"?
To swith between edit and preview mode try ⌘ Cmd+R. You can aslo get to that from the view menu.
Hi Doug!
I mean that in mode ‘edit’ I don’t see most of the pictures I can see in mode ‘preview’. They simply disappeared after the republication of my site.
There’s something to do?
ps ‘online’ I can see everything
Maybe some more information would help.
- What version of RW?
- What Page type (plugins are you using?
- What version MacOS are you running?
- Some screenshots of what is happening?
One example where images are not visible in edit mode are direct resource references. Not sure if that’s your situation though.
Eg. <p>some text <img src="%resource(Pointer@64.png)%"></p>
Hi Doug
What version of RW? *RW 8.7
What Page type (plugins are you using? Styled text and album photo no plugins
What version MacOS are you running? Catalina 10.15.7
Screenshot 1: what I see in Edit mode
Sreenshot 2: what I see in Preview mode
*The site have been built mostly with with RW 6.3 and today I deleted this old version.
Maybe I should get it back somewhere.
