Publish Woes - Unable to test
Evening All
Odd one - not seen before.
A file ( RWC 9.5.0 ) - that won’t publish, it won’t even test the FTP connection…
The file is good - or at least was good, its been published plenty of times.
What’s weird is - I can use exactly the same credentials on another file and it works perfectly - as expected.
Perhaps the files corrupted? Maybe, so I went to earlier versions - exactly the same.
So - I then thought - ahhhh - let’s just copy the contents to a new fresh file… but of course, RW doesn’t make that easy if you’re using subfolders to organise stuff - unless of course, someone could enlighten me?
Thanks all!
OK - I’m an idiot ( its been a long day… I blame the recent update… blah ) but for some reason the FTP mode had flipped to Active as opposed to the default Extended Passive… doh
I am experiencing intermittent “publishing” issues since the latest Classic update [I am running v 9.5.0 (21134)] – the frustrating spinning “beachball”.
I have to force quit Classic and start up again. Prior to this update, hitting “Publish” started immediately and ran smoothly.
For context, I am running Sequioa and the site is saved to OneDrive.
I get this error message when trying to view:
Using RW 9.5
that could be the problem. try it from your hard disk
