If you want to point it to your hostgator account, you’ll need to change you NS servers on your domain registrar.
If you set yor path to blank, it’s only going to go where your FTP acct directs it. Next time use the Browse button and find your public_html/ folder and choose that
Thanks for your response. Just so you’re aware I did use the BROWSE button.
Also the NS servers are pointing to Hostgator. The site name I put in the message is ficticous. When I use the propagation checking tool you gave me with the correct URL it propogates correctly. Sorry for the confusion.
The situation hasn’t changed though. It doesn’t matter what I put into the BROWSE I don’t get to the home1/public_html it just allows me no higher in the tree than home1/myownurl/myftpname
