I have used the same publishing information for both the elements and classic projects. The classic publishes no problem at all. Both connections are OK. Then, if I try publishing the same file (with different text). Nothing. What is even more annoying is that every time I try it and publish it in Elements it uploads 2,600+ files and I have a wait to see {no} result.
Hi, does the publishing go through? If so, please check if you have an index.html an an index.php file on your server, both. Then delete the older one.
solved, thank you for your assistance. I am elderly and still trying to grasp these things
