I copied the setting of a site from classic to the new elements, it does not work: click on test in classic is qll good, on elements it says “could not sign in to your sftp server”
Second problem, i am just starting with elements beta today, just exploring, image does not seems to work, it does not appear on preview at all while everything else does
With the same layout (container with a picture component inside), try from resource (after you had place images in). It works for me, Elements up to date.
I found out what does not work, jpeg, png all ok, but webp is the one that is not working, I thought the new RW Elements would be able to handle this format, may be later
