Random CMS - custom component
CMS custom component, have shown before, but extra functions
ok I have only 3 images setup you can add more
This randomly selects an image, the relative link, text color and the link text
Highlight a different product or page as you land on the page, every refresh or visit
Elements CMS is really cool :grinning_face: :grinning_face: :joy: :joy:
Where and when can you buy that?
add some controls, part controlled by CMS the rest Elements
Home is the only page random image/text is used the other pages are just pages, the random image text link the other pages
might be of use, project - elementsapp://downloadDocument/LbAUsiZqvuiE
leave until tomorrow, uses up space
if you need to point at different md folder and md frontmatter
just posted free
you could add more in the frontmatter and change the component
let me know if there are any bugs
Basically, it would be really nice to have a “random item” function in the CMS and in the related item.
Adding whitelist and blacklist filters for the tags would make the whole thing ideal.
THANK YOU SO MUCH! :slight_smile:
no probs, I added project in my previous to last post,
would white black lists be possible in normal CMS
@ben
I think I mentioned this topic before. It’s already on your to-do list, right?
Could you maybe “accidentally” move it a bit higher up the priority list?
That would also be worth something to me as a paid Pro feature. :face_with_peeking_eye:
different project, took a little longer to create, mostly layout in flex
using as a flat data base, set control so far only on card backgrounds
ok another take the array can contain different titles / data, not have data and have data, also editing in ftp - have been editing already, just update a spelling mistake. I would just download the md file and put into the project to keep synced
website - https://sjwjaw.co.uk
Really cool stuff. I just need more hours in the day to really spend some proper time digging into it.
I started here, control flow and conditionals, then followed the links to the twig site, takes longer to create the tailwind code to define the layout than set the twig up
https://docs.realmacsoftware.com/elements-docs/cms/cms/twig
