Hello,
I’m using RapidWeaver 7.5.7 on macOS Catalina 10.15.7.
My hosting is with METANET (Switzerland).
Publishing settings:
- Server:
cicero.metanet.ch - User:
tmnoch - Remote folder:
/httpdocs - FTPS
After resetting the FTP password in Plesk, FileZilla and Cyberduck connect perfectly with the same settings.
However, RapidWeaver still shows:
« Couldn’t sign in to your FTP server. Couldn’t connect to server. »
I have checked:
- the FTP account is correct;
- the password is correct;
- FileZilla and Cyberduck work;
- so the problem only exists with RapidWeaver 7.5.7.
Has anyone encountered this issue before? Is it an incompatibility with recent versions of TLS/FTPS, or is there a particular setting that needs to be adjusted?
Thanks in advance for your help.
