Rapidweaver 8 navigation issue
Hello All :slight_smile:
I am using RapidWeaver 8, Version 8.94; somehow, I managed to deactivate my blog. It is in the navigation menu for site setup; however, it is mysteriously greyed out. So when I published a new blog yesterday, the whole blog was gone. My technical skills are limited compared to others here, and I am recovering from a corneal scratch. I need help figuring this out ASAP. Your suggestions and advice are appreciated.
Jennifer R. Cook www.eloveution.com
Look under General Settings in the Inspector for that page and make sure the Draft checkbox is off. That should re‑enable the page for you. Let me know how you get on.
Fingers crossed for a speedy recovery :crossed_fingers:
OMGosh. Thank you, thank you, thank you. That worked. Totally grateful. I must have somehow checked that box and didn’t realize it. This is due to the issue with not seeing properly. :slight_smile:
Jennifer
Not sure if you received this message. I might not have replied properly
Jennifer
No problem, glad it was such an easy fix :smiling_face_with_three_hearts:
