Rationalising paths
https://www.peteryates.co.uk/2025/references/contact-form/search/
but want .. www.peteryates.co.uk/search/
how do I achieve this when pages are nestled (subs)
your want link is not working just get “page not found” so can not see what you would like.
Sorry Paul - it wasn’t s’poze to be a link
I’m trying to rationalise URLs
ie: I have A. and I want B.
Half the problem is posing the question right : )
Perhaps AI can help ? : ) … translate to Dan-tech speak, German or Woman
The simplest way is to not nest the page, put it at the root.
But that breaks the Nav hierarchy, no ?
You can do what you want, but you’ll have to modify the .htaccess file on the server… I wouldn’t recommend doing this, it’s error prone and easy to mess up.
A simpler way would be to put the search page at the root, and then create a “link page” in your navigation that points to the search page url.
