ReadTime display problem with Elements 3.0.x beta
Hi @Massimo I just tested my project with the new Elements 3.0.0 and 3.0.1 betas and found a display issue with your ReadTime component. It is now displaying an additional button box on the right side. This is new with Elements 3.0.x and it’s Tailwind 4 CSS. May be you will find time to take a look and fix this before the final release of Elements 3. Thanks.
Hi, I’m sorry, but I’m on vacation abroad all through July. I’ll try to take a look when I get back in August.
Hi @Massimo Enjoy your vacation!
To help you I tracked it down to the following code (wondered from the very beginning, why you did place this code into the component, as it bloats the CSS file by loading all CSS classses).
Hi @Massimo
Hope you are well back from vacation. Did you by chance had a look into it? The fix shouldn’t be that complicated, it is just to remove the DIV shown above from your code. Actually I do that manually in the index.php after publishing all the time, but that’s cumbersome. An update will be greatly appreciated.
Hi @Massimo
Hope you are well! Did not see any activity from you here since more than a month. I am concerned something could have happened to you during vacation in July. I understand, if you have more urgent things to do. That sometimes happens, but pls. send a sign, that you are still there and healthy.
Kai-Uwe
Hi, thanks for your message. I apologize for the delay; I’ve been on a long break from work.
Currently, I am holding off on updating my components because Elements 3 is not yet an official release. Pushing an update now would break compatibility for users on the current stable version of Elements.
My components will be updated to TW4 once Elements 3 is officially released. Thanks for understanding.
Hi @Massimo
Glad to see, that you are well. I understand your position regarding Elements 3 and will wait until the official release.
Hi @Massimo
Sorry to be nasty with this, but this problem which is requiring a small fix (one-liner) is starting to really annoy me. Elements 3 is out of beta since 3.0.14 published on Sep 15th.
I would really appreciate this one to get fixed now. I beg for your understanding, I struggle with this problem since July 15th now.
Hi @Massimo
Do you have any news on that? Are your components still supported?
Thanks Kai-Uwe
Hi @dan
Maybe you are able to help with that one. The affected component, i.e. ReadTime by RW Pro Space is still listed in the Elements Store but not compatible with Elements 3.x (Tailwind 4). I honestly don’t know how to handle this better after having tried to get this fixed since July.
Thanks Kai-Uwe
Hey @herbing, totally understand your frustration… have you tried emailing @Massimo as he might not be checking the forum?
Hi @dan
No, I didn’t try email yet, as he did respond on the forum in the past and I have no email address. I had the hopes you have a more direct connection to him, as you are operating the store. Sorry to bother you, but he promised the updates for the final 3.x, that is available since a good month now and I am a bit tired of dealing with this matter.
Kai-Uwe
Hi @Dan,
Kai-Uwe has been exceptionally polite and patient, but you do still think he should to get in touch with Massimo himself? Isn’t there a role for Realmac to play here?
Contact and Support | RapidWeaver Pro Space for a contact form and email address
I have just sent an e-mail to his support mail address. Let’s hope, I will get a response there. Thanks @ercross for pointing me to his website.
We’re also reached out via email so will let you know once we hear back :crossed_fingers:
