I was referring to your blog enhancement kit. That would be great for my site.
It’s documented here: GitHub - willwood/RapidWeaver-Blog-Enhancement-Kit: Adds extra features to the RapidWeaver blog page type, in ThemeFlood themes.
You did all that with the Armadillo Blog stack? Wow. I can’t even figure out how to get the sidebar to work right. Do you have a lot of coding experience?
PJ
Hi PAProf, Tee hee thanks! I have NO coding experience whatsoever ;-).
I just put the blog stack itself in the left hand column, all of the sidebar stuff is actually in the side bar tab in the inspector panel, not in the body of the page at all. I then used a ‘sidebar’ stack to pull all of that information into the right area which is in the right hand column.
Getting the twitter feed means going into the twitter accounts widgets area and just copying the code in, and the same goes for Flickr and Pinterest.
Does that help at all?
It does! Thank you! I appreciate your response.
Your page is really cool.
