Is it possible to make a custom address (e.g. website.com/info) for a a CMS-page (website.com/blog/?item=info)?
I tried to do this with a redirect, but I’m not sure this is what I’m looking for, as the redirect doesn’t work.
Can you describe a little more about what you are trying to do? For example you can give your CMS any folder name you’d like (news, articles, info) etc. It doesn’t have to be blog.
I might be misunderstanding what you are trying to accomplish, so let us know.
Hi Daniel,
Thanks for your reply.
What I would like is create a short link to a CMS-page. The folder name is not the problem. The shorter link would be a nicer and more readable way to direct to the url of the cms-page.
So in my case: is it possible to create an url like https://atwot.be/multiplenoise directing to https://atwot.be/luisterclub/spoor/?item=2-selectorsets ?
I tried to do this via a redirect, without success, so I’m guessing that’s not the way to do it.
Thanks for your help,
Jeroen
Well /multiplenoise doesn’t exist, so I guess that’s what you are trying to create the redirect for.
I set up a redirect in Cloudflare for you, so /multiplenoise is redirecting to Another Terrific Waste Of Time , but I don’t think that’s very elegant.
Why not set up pretty URLs so you can just make those long https://atwot.be/luisterclub/spoor/?item=2-selectorsets URLs more…pretty? ![]()
The CMS gives you the ability to enable pretty URLs per the guide here Pretty URL's | CMS | RapidWeaver Elements Docs
Thanks for setting up the redirect in Cloudflare. That’s exactly what I wanted.
I tried to do it via the Elements Hosting control panel, without success. But could I have created the redirect myself in Cloudflare? I logged in, but couldn’t find the option to create a redirect.
Previously I tried to set up Pretty URL’s but that didn’t work out well. I’ll have another go at it, when I have more time.
I’m surprised you think the redirect you created is not an elegant solution. The redirect points out to a page where there’s more info about my work as a music selector with the alias multiplenoise, one of my activities under Another Terrific Waste Of Time. Hence, the redirect I was trying to create.
No problem. ![]()
Should be able to locate it here, let me know if it’s not showing there for you.
If you need any help with it, let me know. Pretty URLs would be the preferable way to go about it.
If it’s a one-off redirect it’s ok. But if you were wanting all your CMS/Blog URLs to look nice and tidy, then these kinds of redirects aren’t scalable. Pretty URLs would handle this automatically so the URLs look nicer without having to go and add a bunch of manual redirects.
I don’t see any domain on my account at Cloudflare.
I sent you a DM to sort that. ![]()
